1 - 4 of 4 Posts
Hello, I'm looking for some feedback. I'm putting a 6 in lift on my tundra this weekend and with 35s the speedometer is going be off and maybe the gears idk. Is unichip my only option? I'm not sure what to do make sure tundra runs right after the lift. Thanks
And you will be -5 or so miles under the speed you actually going without it. For example when you speedometer reads 65 you'll actually be going 70, etc.
Somewhat accurate. You will be off by a ratio or percent. Say if its 7% off (roughly what it should be) if your speedo reads 100 you'll be doing 107. In the same scenario if it reads 50 you would be going 53.5 or 25 would be 26.75.
1 - 4 of 4 Posts
