1 - 9 of 9 Posts
I just recently lifted my 2014 CM with an OME 614 and +3 Coachbuilder shackle and the truck sits level. When I hook up my 3500lb travel trailer, the back end squats down leaving me with a negative rake/sitting nose high.
What options would you recommend looking into to correct the negative rake and level the truck when towing?
3500lb trailer squats the rear? No way. That's minivan territory.
Better check your trailer weight, tongue weight, and how that thing is loaded.
Otherwise air bags are a great upgrade, just not cheap.
What did you think was going to happen with a leveled truck?
I'd prolly add bags in your shoes.
Truck does look good.
Cheap fix that will work great - Add some helper springs
1 - 9 of 9 Posts
