Good evening everyone,
I am in need of serious help. Here is my current setup. 2015 Toyota Tundra CM, 4x4, with bilstein 6112's and 5160's. I just installed a diff drop kit and Camburg upper control arms. When I took it to the alignment shop, they told me that they could not get my Toe alignment correct. One of the guys suggested that I cut my tie rods. I really don't want to do that. My toe is off by -.4
Does anyone have suggestions on how I can fix this alignment issue? My caster is maxed on and my camber is within spec.
Thanks.
agreed! unless your truck has damage, you've got nothing wild going on in any way. nothing should b maxed and you should have adjustment leeway to get everything in spec driving nicely. go somewhere that knows how to do an alignment, not just drive the truck up onto a computer pad
Hey All,
Just a quick update. That was the issue. I took the truck over to another shop today. She's now all within spec, minus caster which is 6. But, added caster is what I wanted. I went from -.46 degrees on Toe, to +.10 on both sides. Thanks for the advice all.
