41 - 50 of 50 Posts
Discussion Starter #41
No problem, the barley fit in the slot at just a slight angle. Which actually looks good with how the angles are already cut in the plates. And I️ just used a pair of dikes to cut the expanded metal. Then drilled out the holes. Also I️ bought a pair of h11 extension plugs off amazon so the plug directly into the fog light circuit.
Sent from my iPhone using Tapatalk Pro
Looks great I’ll have to do the same.
Between the flush mounts and the light bar I️ have full 180 degree of usable light output off the front bumper
Just installed this radius bumper...love the look but I’m having clearance issues with 37s. I guess I will see if taking a few inches off each end fixes it.
That is an awesome looking bumper.
What is the offset on your wheels?
0 OFFSET im pretty sure...its the 17 inch method standard...if I remember the 18s in the same rim have +18 offset. I cut back the bumper a couple of inches and it fixed the bumper issue...….now I just rub on the inner fender area....
41 - 50 of 50 Posts
