They don't tell ,, the failure statement only threatens me a penalty summons if I don't figure out what they are hiding from me.. these officials are as cold as the air inside that inspection station at paramus new jersey. I asked the guy what it might be because there is no engine light to know and he said go figure it out or take it some place! I believe this is how officials fill their deep pockets imho. even the motor vehicle inspection in nj is tied to corruption. Otherwise they would at least reveal what they diagnosed as failing. not sure what tools or sensors they used.Was this a sniffer test or OBDII only? If the OBD shows the computer as being "NOT READY" some states will fail it even if there are no codes present. Did you recently disconnect the battery? That would cause the not ready condition.
If everything checks out, I'd try a different testing station.
I just changed my air and fuel filters, also jiffy lube does my oil changes.. I never did a plug tune up , she idols like brand new.. I suppose I could pay to have it looked at but, I honestly think it is todays fuel mixes at the pumps and older vehicle's fuel pollution controls design taking the blame. maybe this 2001tundra is better off with high test octane? I always use cheap 87 octane.. maybe that is it too?Maybe try some kind of fuel system cleaner or a tune up. I've always been told to make sure the cats are good and hot so they are cleaning to the fullest when they put the sniffer to them.
If you read above, I have a cheap Maxiscan tool and no codes , meaning it is likely what the others here are suggesting.. I honestly believe it is a government conspiricy.. not that i ever been arrested but, perhaps they are slowly prgressing us to go to their racketeering businesses and certified garages? I think this is it .. sh-ty expensive deteriorating mixed fuel passed by those we voted in and entrusted to serve and protect but, it is actually a big inside job for government corruption.Ask around to see if they do a sniffer test, local parts guys are good sources for that sort of info. See if you can find a Scan Gauge or get one, it will show the computers status and any codes or impending codes.
Okay i will but, if the plugs were all that bad, wouldn't the engine light come on under stress ? I don't recall ever doing plugs so I will ck. btw 150k and tundra strong knock on wood!Check your plugs, if they are original I'd replace them if over 60K miles. Bad plugs will idle fine, put them under stress as in a loaded sniffer test and things can change quickly. Use 93 of you want to, 87 is fine for that motor though.
Found the issue. You don't have any oil. :lol5:I just changed my air and fuel filters, also jiffy lube does my oil changes.. I never did a plug tune up , she idols like brand new.. I suppose I could pay to have it looked at but, I honestly think it is todays fuel mixes at the pumps and older vehicle's fuel pollution controls design taking the blame. maybe this 2001tundra is better off with high test octane? I always use cheap 87 octane.. maybe that is it too?
You are right in that sense but, why in this day and age of smart phones highspeed data, would a state inspection station not have easy diagnostic tools to help the hands that feed them? Believe me when I state what I mean..the government officials DO turn a blind eye for the power of money these days. jmho, hope no offense is taken,, no not cheap, just a realist trying to get things in order. thank you tooAre you really that cheap that you are going to jerk around and blame corrupt officials? If they were corrupt, you could have flashed them some cash and got the info.
A dozen year old vehicle and you expect it to be like new? The tests for old vehicles take into account the old standards.
And you haven't done a tuneup yet on a failed vehicle?
brb, i'll ckFound the issue. You don't have any oil. :lol5:
Thank you sir!!! God bless you too! ..GOING TO DO THAT PLUS CHECK MY PLUGS TOO.. I do have a can of seafoam spray,, acetone ? not sure what that is but , i'm going to take your advice and hope I find a good tutorial on youtube.. btw, off topic but all this time, am still waiting on my phone to get a turbo tax rep. to speak to for first time turbo tax... was using an accountant who charges 185.00 for my little small handyman business.. i'm not so proud to admit i'm hardly making anything these days.. hoping to save something using turbo tax but will not tolerate a runaround..this wait is rediculous! well over 15 minutes and the wait music is sad ! very depressing lolIf you haven't already run a tank of seafoam through your truck, this will not only clean the injectors but clean the carbon in the heads. The cats work after the exhaust temp reaches 700-750 degrees. After you've run the seafoam out fill up with 15 gallons of 91 or higher octane and 3 oz. of acetone. If your truck runs good You will pass... the acetone is the key. It allows the fuel to burn much more efficiently and reduces hydrocarbons to extremely low levels. You'll also enjoy about 40 more miles in that tankPlease update.
