This post is useless without pics!
from what I read about the sst 4" you could run the stock 18" TRD rims and fit 35" tires with no problems. maybe your new rims caused the issue of rubbing?
I'd be interested in pics of how it rubs. also interested on your take installing the upper control arms and the ease of alignment afterwards? did it align to stock easily for the tech?
I am thinking about using this kit as well, but also adding a carrier bearing drop kit and a driveshaft spacer if it is needed.
Thank for fixing my pic. Also thanks for the spacer info!!!! Good luck on order too. Share pics when you get it.the spacer I'm talking about, not a lot of people think about. but if you start getting vibration and stuttering when going then you will def want the carrier bearing spacer. it drops the carrier bearing down so that it is at the proper angle, and I'm sure it helps with pinion angle too. (basically the same reason the readylift comes with the diff spacer to correct the axle angles) the driveshaft spacer is to make sure the shaft is properly set in the end of the transmission. basically a slip yoke extender.
ready lift states stock rims are good to go even with 35", so I'm glad to hear it was your new rims causing you issue, but only because that means that my stock rims will work not because I think it is funny or anything.
thanks for the feedback, I posted about this kit and nobody responded to my thread, so this was very welcomed for me!
good looking truck, I'm about to order mine today and I'm stuck between the dark grey and the light silver. I think its gonna be silver sky for the win because I like the red 4x4 on the trd off road on that truck....on the dark grey truck it is a light silver and doesn't contrast well imho.
here is your pic corrected.
Yeah, easy to tell apple was involved,lol.Sorry can't get the pic to rotate. Doing this from iPad
Well I may be doing this. Have you done this? For some reason after installing my spacers 1.25 the rubbing was worse. It now rubs way before the body mount and hits the front bumper when turned in. Ugh. Pissed right now. I called ready lift yesterday before I over nighted the spacers to my house and they said it would fix the problem. Going to be chewing some [email protected]@ in the am.Get the body mount chop done to eliminate the rub and you should be good to go!
So my suggestion to anyone that gets this kit don't do any less than a +20 offset. The +1s that I was told should work, key word should, is kicking my [email protected]@.
Thank you, one question with the chop. Does welding a plate back in place just an appearance fulfillment, or is it to add structural value from chopping the mount back so much?If ready lift told you spacers would fix it then they are dumbasses. Think of it like this. If your tire is hitting the body mount at the current offset, then adding a spacer (negative offset) increases the swing radius of the edge of the tire so you will only hit the mount and everything else worse. Take the spacers off and get the body mount chop done. I stuffed 35's on +18mm Method Standards on a bilstein leveling kit. A higher offset (positive offset) will help tuck the tire in to the wheel well and reduce the swing radius. Our trucks actually have a lot of space inside the wheel wells aside from the body mount. Here's a pic of my 35's on my truck with absolutely no rub at any point. View attachment 515042
