1 - 10 of 10 Posts
I currently have 33"s under my 2011 Tundra. I have installed the Rough Country 3/1 leveling kit and seem happy with that (for this minute). I was given a set of 35" TOYO Open Country M/T tires and would love to put those on the truck. I know I would have to trim some to prevent scrubbing. Does anyone have any input on 35's with just a leveling kit. Has anyone learned the hard way that this can be done without a big problem or is this not the way to go?
a lot depands on your rim size and offset
They are 18 inch rims. Due to buying them used, I am unsure what the off set is. The size of the tire is 35x12.50
Will do. I would say they are 35mm offset due to them sticking out from the fender about .5 inch to an inch. Thanks for the insight.
Are you saying your tire sticks out beyond the fender 0.5 - 1 inch? What size (width) is your tire?
@chphilo.......The tires that I am running now are 325/60/18's. The Toyo Open Countrys are 35x12.50
im runnin 35x12.50x20 mud grapplers on a 20x9 with a +35 offset, i trimmed the side sections off of my skid plate and pushed the plastic forward and rescrewed it in the front of the fender well and i have no rubbing on a 3/1.5 level. i with the 1.5 to give little rake since i pull a boat in the summer didnt want it to look sacked out all the time with anything behind it.
1 - 10 of 10 Posts
