1 - 20 of 65 Posts
HID Retrofit Lord
Finally, I got some time to work in my truck, so my lighting mod is almost done, I just need to swap all the stock bulbs to LEDs and I'll be all set ;)
I wanted to keep the LS460 retro but, After seeing the ls430 output I was like I have to have them. So here I'm with an amazing projectors that is making my Platinum look like a Real Platinum.
Since I love the challenge I decide to match the Ls430 with mini h1 and they came out almost perfect.
Here is the component list for the DIYers
Ls430 projectors
Mini H1 projectors
Philips DRl Daylight 8
CCFL angel eyes from AAC
125 mm Angel eyes for the fogs
CBI D2S 5000k Bulbs
H1 morimoto bulbs.
D2s adapters for H1 bulbs
4 Matsushitas ballast (OEM infinity ballast)
2 heavy duty hid harness
2 toggle switch for Angel eyes and the mini projectors.
3m Di noc
JB weld
3m Fast cure urethane
4 3' Rain end caps to cover the projectors
Electric tape ...
I used stock bulbs to make the connection a 100% plug n play.
If you want to see my philips LED DRLs retrofit
click here!
I started by aiming the high beam first (mini h1) with the stock low beam to make sure they where at the stock level.
Once the output match perfect secure the projectors with 3m fast cure urethane.
Installing the angel eyes
Installing the toggle switch's
headlights installed
:cool:
Do you want to see them in action?
I made this amateur video so please bear with me
very nice.
thats sick, in the end how much did it cost you?
how did you get the autoleveling system to work?
Wow...those are nice!
NICE JOB ! ! !
Looks like alot of work but very nice.
god i wish i knew how to do this kind of stuff, im more of a mechanical person, plus my dad works for lexus so i can get the lights pretty easily
Only thing I didn't want to replace is the high with HID cuz HID takes a while to come on so you can't really flash. I live in the city so almost never use high beam (except for flashing).
BTW, did you retrofit projector into fog? :)
HID Retrofit Lord
Discussion Starter #17
I'm using OEM matsushitas ballast on low n highs, they will flash at their maximum no matter what.
That's why I always recommend them :D
I didn't do a retro in the Fogs because the mini's has a lot of foreground it would be overkill.
I'm loving the way the Angel eyes make the fog housing shine!
Would you mind showing a vid of the flashing while the headlights HID are initially off. I want to retro the high beams now too haha
Reactions: TRD-X
1 - 20 of 65 Posts
