1 - 6 of 6 Posts
Banned
hi all, curious if anyone has had anything like this happen.... the other day I was driving down a straight paved road, heard a distinct loud pop from under the truck, much louder than a tire throwing a rock. looked around, didn't see anything, the next day I go to leave work and both front tires on the truck are cambered way out, looks horrible, get it up on the lift and camber was ok, but the toe was way out, did an alignment and solved the problem. wondering where this "pop" came from. Nothing obvious on the outside. I had just replaced the steering rack 8 months ago, im wondering if something internal broke? any ideas. FYI, its an 08 tundra, 6" lift with 35's.
Banned
OK???? Joints look good. Grab the tires and shake em and nothing is sloppy like a bad ball joint. Everything is tight. Doesn't make sense.
Maybe one of the cam adjusters slipped on the lower control arm.
Reactions: dirtydeeds
Banned
adjusters looked ok, ball joints were ok, nothing looked out of place. could it be something internal on the rack? wouldn't I see a major problem if it was internal?
1 - 6 of 6 Posts
