Hey guys/gals. this is my first post here. I have a 08 Tundra 5.7 TRD with 230 000 km and to be honest it has treated me great. However, i have the pesky limp mode happening off and on now for about a year and lately its more often than not. So here's the deal....the code reader tells me it the secondary AIR injection pump malfunction and the dash lights that gets thrown on are the check engine, 4 low, anti skid and abs. Funny thing is, sometimes its just the check engine. So i will reset the codes with my reader and it will be fine for the remainder of the day most times, especially if its dry. On wet/damp days it will set off frequently, usually on every start up.
So what i'm trying to avoid is a costly bill where they try everything under the sun to fix it and after 2K later its fixed and a dozen different parts have been replaced. My thoughts are if its actually the pump itself defective then i shouldn't be able to reset the code successfully daily. And since its worst when wet outside, it leads me to believe its more electrical related and maybe wiring???? Any and all help would be appreciated. Thanks in advance
