1 - 20 of 29 Posts
Lighted cupholder mod
Well Ive seen on some other forums this mod done, and also got annoyed by how dark the center console is at night especially with tinted windows. I Figured EL wire was perfect for the job, ive used this stuff before on my pc. I used an EL wire kit from Xoxide.com. Its 2.3mm dia.
Just a few pics showing what i did.
Drilled a hole in the back side and mocked up the wire, and pre formed it to the shape of the cup holder.
Got it all glued in place. Used just a little bit of plastic glue around the lip. Fit perfect.
Wired everything in to the 12v plug that only on with ignition and drilled a hole for the wire to run through under the cup holder.
Everything back together. Shot in daylight and you can hardly tell its on. Perfect.
Ill upload a pic or 2 tonight once its dark outside.
Let me know what you guys think!
Ok, I think its dark enough to see in the pics.
Flash on:
No flash:
It looks kinda blue on my cell phone camera, but it is actually white.
The third cup holder and storage compartment may get done tomorrow. Pics will follow.
Actually EL strips and wire are exactly what was used to make the TRON costumes. You can buy AA battery packs to power about 40ft of el wire for an entire day...
Reactions: thetastelingers
I like it, I would have put it in the bottom on the lip though. how does white look at night? I might have went with an orange to match the other lights. Is it inline with your driving lights or always on with the truck? how bright is it?
The white looks great to me! Its not very bright like LEDs would be. Its just a wire that illuminates. For the time being it is wired in to the cigarette lighter, so its always on with the truck, though i will be wiring it in with the headlights so its only on at night to help it last longer.
I Kick Hippies
looks good! thanks for the info on EL wire, never heard of it before.
My '09 Ford Fusion had the lighted cup holders just like this. I could change the colors but always left it red. It made me feel like I at "battle stations" in a submarine since I had 5% tint.
I can think of a ton of stuff to do with that wire. What's the average lifespan?
The stuff should last for years. It does eventually dim, but its hard to know just how long it will last due to quality variance from different manufacturers, kinda like cheap vs good LEDs.
Update, did the other cup holder and the little change holder as well.
Decided to tap power into where the cupholder LED is (Blue is +, Brown -). This is also controlled by the dimmer, so i can now control how bright the EL wire is, not that its very bright anyways.
Reactions: 909SCUM
This is a great mod !
I'm going to have to do this!..... Where is a good place to buy "EL" wire?.... I like the idea of tapping the small existing cup holder light so you can control the brightness with the dimmer.
Great Idea pbasil1
Discussion Starter · #15 ·
There are many various wire sets out there, I bought this one from Xoxide.com and got a splitter + a second strand of el wire. They have many colors and are cheap. Its designed for a computer, but i just cut all the extra wires and switch off and just direct wire it in.
Also, to be noted for those unfamiliar, el wire can simply be cut to any length. no splicing or anything needed. Just a pair of scissors.
Some pics of it all done:
Flash on
Flash off
Oh boy... I've found a new addiction....
1 - 20 of 29 Posts
