Was looking into getting toytech 1-1.5" shackles but the link from bilsteinlifts.com says they will hit the drivers side tailpipe. Anybody running lift shackles with the trd duals? Copied from site:
1-1.5? Lift Rear Shackles (Adjustable) by ToyTec for 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017 Toyota Tundra
Part: SKLTUN
Included in kit:
(2) Adjustable Rear Lift Shackles W/ Grade 8 Hardware.
These shackles are made to withstand even the toughest conditions! 2?x3/8? steel legs, heavy-duty cross member welded in for extra support, and zinc plated for a long lasting finish.
Adjustable from 1? or 1.5? of lift so you can dial in your overall rear lift height.
Add new lower Energy Suspension replacement bushings from drop down if desired.
Note: Lowest hole setting is not used on Tundra’s
TRD PRO Tundras use a special exhaust system that doesn’t allow the shackles to work because they will hit the exhaust. Exhaust pipe modifications are required in order to use this shackles. As you can see on the picture the dual exhaust is on the sides and very close to the rear leaf springs and by pushing the leaf springs down with the shackle it will be touching the exhaust pipes
Part: SKLTUN
Included in kit:
