Really, I haven't really seen this discussed in depth here yet.
Most decent priced components that non pure sq audiophiles call for about 60-80 watts rms, example Pioneer D-series...
They are a great sounding speaker, especially for the price.
However, at 60 wrms they don't hold enough on paper to work with most 5 channel amps. (Ex: JL 900/5hd @ 100/4, or Alpine pdx V-9) Both amps are a great amp, and can be a great value when you consider that you get a small footprint amp that offers ease of installation and a sub channel cranking out 500 watts rms @ variable ohm load...
Many say that with the great dampening control of these amps (especially when ran at 4 ohms) that you can safely send the extra 40 wrms to the speakers and if gain is set properly you will not have an issue, however there is also that side that says if you crank it you will burn the voice coils out...
I currently have D series, got em for my b-day ( I was going to buy them anyways, just keep buying guns and ammo)
I have looked at other components in my price and desired quality range and they are all about the same specs as far and rated rms handling.
I am curious to see what you all think...
I can get a GOOOOD deal on either amp, I know that they are pricey normally, but at less than $500 for the pine nib from an authorized dealer and about $700 for the Jl also authorized, they are both easier than buying a 4 channel and a mono amp... The Jl also takes high level inputs, not sure about the pine... That means when utilizing factory head unit one could do the install without a loc or a processor while they save some $$ to upgrade later...
It is this or do a throwback install and use my vintage rf 4.6x ( one of the last series hand built in U.S.A.) which is appx 35-45 rms x4 ( which would be wayy safe, but not offer full output capability of the speakers), but then still need to buy a mono sub amp, and then do a dist block...
