1 - 20 of 25 Posts
Does anyone have any pics of an LED bar mounted behind a TRD PRO grill? I'm thinking about doing that rather than using the Nfab Mount that I have. Some pictures and a description of what LED bar was used would be awesome!
Or in the bumper. I'm undecided if I want one in the grill or in the bumper.
2016 Toyota Tundra TRD Pro CM MGM
IG: @kt_harb.protundra
Here ya go.
Sent from my SM-G900V using Tapatalk
No photo attached.
Ugg, photo won't load from my phone will try to post from computer in a few.
Reactions: ktharbour6
OK, let's try this again...
30-inch Cree LED Light Bar - (Dual Row | X5 Series)
16200 lumens
180 watts
Dual row
Here's a 40"
How do you like those headlights? How long have you had them? Any issues? Plug and play to original wiring only or more stuff due to the projectors? Are the led strips always on like the amber light? How bright are they? Better then the OEM headlights that come on the tundra? Will I need to buy headlights for it as well? Thanks in advance.
Lets see.... I Love em, about a year, no issues, yes plug n play, Not always on I leave my lights in the courtesy position to keep them on all the time, they could stand to be brighter so a lot of people upgrade to HID, They come with halogen bulbs.
So they come with everything needed...? Just to be sure. And to have the LED light on I have to turn on the parking lights basically... Thanks again man.
Yep, you got it right man
32in eyourlife light bar about 6 years old now no problems no leaks ebay special.
There is a cross bar that you can drill mounting holes into really easily and use the brackets that come with the bar. Just make sure you mount the bar back far enough that the grille will still pop back on.
I like the Lund Bull bar with LED. Almost pulled the trigger on that, but ended going for the Revolution Bar from Lund, is a bit more squared off.
What are you guys using to switch on your AUX lighting/LED bars? I'd like to slip something into the blank spot where the mirror/headlight adjust and others are for a stock look. I've also seen mini din switches tucked under the center stack/HVAC controls.
1 - 20 of 25 Posts
