1 - 10 of 10 Posts
Hey guys, i have been looking at the forums a lot and wanted some opinions on what are the best LED light upgrades. I plan on buying the reverse LED's and 3rd breaklight led's/cargo bed LEDs from VLED listed under the Tundra fit.
I do like the VLED V3 upgrade but it is too expensive, are there any other options?
Also, What are the brightest stock headlight replacement?
I don't want to go HID yet, just replace to a brighter bulb.
Cereal Killer
Just put the new bulb and the old bulb side by side. You will see the differences in the tabs you need to trim on the new bulb using small wire cutters. It takes 10 seconds per bulb.
The biggest difference in brightness with this mod is the high beams with HIR1. The low beam upgrade is a fair amount brighter but it doesn't blow you away.
Chief of Grammar Police
1 - 10 of 10 Posts
