1 - 2 of 2 Posts
I recently picked up some switchback bulbs for my front turn signals from headlight revolutions (https://headlightrevolution.com/2014-2017-toyota-tundra-led-front-blinkers-kit-switchback/). I know that if I do nothing with the wiring that they will be amber all the time unless the headlights are turned on, then they turn white. Does anyone know how they will react if I do the DRL delete mod by clipping the pink wire under the dash? Will the lights be white with headlights on, amber when turn signals are on, and off the rest of the time?
Thanks
Edit:
Note from the website regarding the circuits used for the LED:
The original amber DRL function uses the bright circuit of the bulb (amber).
The original parking light function uses the bright circuit of the bulb (amber).
When headlights are turned on, the dim function of the bulb is used (white).
I'd like to know this, as well.
I just put in a pair of switchbacks (Amazon) and I'd really like them to be white when functioning as DRLs, or off instead of amber. Otherwise, they work nicely.
Anyone?
1 - 2 of 2 Posts
