1 - 20 of 46 Posts
I think I have everything figured out to swap up to LEDs for turn signals, brakes etc.
going with the Vleds resistor (VLR-3) one on each rear, and then SiriusLED brand bulbs 3157CK for front turns and rear brakes.
they dont have a red 921 for the rear turn signal
What are you guys using without dropping 80 bucks on the Vled bulbs?
these look awesome, but damn 40 bucks per bulb
http://www.vleds.com/shop-application/turn-signals/turn-signals-rear-921/921-6-r.html
seems 921 red for turn signals is slim Pickens
I bought one of those red 921's for my 3rd brake light. I also bought the new high output 921's for the cab lights and reverse lights. I use the cab lights to slow down tail gaters. I'll try to get some night pics of the output.
which red 921? the Vleds?
if so, Im looking for an alternative as I don't want to spend 80 bucks on two bulbs for turn signals
or did you buy a different brand 921?
I just replaced two bad oracle reverse lights with Vleds.
Do it. These lights are bright.
It's weird the oracle reverse lights let me down three times in five years. But the same bulb is in the cab light with no issues in five years.
I was just looking for a non $40 a bulb option for these 921 red
seems like nothing so far
Yes, it is the VLeds 921. I run all VLeds on the exterior to include the headlights.
Did you get the 850 lumen set? They are insane in the cab light position as well....works great for tailgaters.
I think its a newer version. 1050 lumens each. Good idea about the tailgaters.
Sent from my SM-G930V using Tapatalk
I just looked.....those are the ones that I have.
ok, back on topic
921 Red, other than Vleds
Discussion Starter · #15 ·
Discussion Starter · #16 · (Edited)
Found that these 921 can just be dropped right in no hyper flash no resister needed for rear turn
If this works I’ll then move onto figuring out the front. Vleds look awesome but just too much money
Going to try them, I have a bunch of other bulbs by siriusled and they are pretty darn good
Couple dudes on tundras.com use them and they work really well
SiriusLED High Power Extremely Bright 3020 Canbus Error Free 1000 Lumen Xenon White 921 912 T15 Backup Reverse LED Light Bulbs https://www.amazon.com/dp/B01M7SNRLA/ref=cm_sw_r_cp_api_ZDfeAb0KBZ8FM
Discussion Starter · #17 ·
I'm going to sub to your thread and look forward to hearing your results.
I'm also wanting to go LED with front and rear turn signals.
I agree the Vleds are very expensive.
I ordered LED front parking light, interior, and license plate bulbs from Headlight Revolution.
https://headlightrevolution.com/vehicles/toyota-tundra/
One plate bulb went out after a week, and they sent me another one no charge.
4 months so far so good.
Today I ordered cargo and 3rd brake light bulbs from them.
I'll see how that goes and might buy F/R turn signal bulbs and resistors from them.
That would run about $120.
Going to wait and see how your bulbs work out.
I've never had luck with any LEDS I bought from Amazon.
The interior lights from Amazon flickered after a month, some stopped working.
Same goes for the plate lights I bought on Amazon.
But they were all cheap ones.
Discussion Starter · #19 · (Edited)
This brand is kinda mid grade, not super cheap but no where near vleds
I have my wife’s entire sienna done with them and they have been good
I have their 921 in my two cargo lights and third brake lights and they work awesome
They blow away the headlight revolution ones I took out
I’ll update again when I get the brake light bulbs and these miracle turn signals that you don’t need a resister for lol
Oh sh!t, I may need to cancel the order!!!!!!!!!!!!!
1 - 20 of 46 Posts
