Have 3/4" more clearance between the tire and the wheel well on the left rear verses the right rear. Front has 2" rancho quick lift and measures up the same on both sides. Doesn't look like anything is bent or wrecked in rear frame/ box assembly but I thought a weak rear spring would make the whole side sag. Any thoughts on this would be great.
usually the low side is the drivers side. I would tell you that it is normal and there are a thousand threads on this, except you are saying the wrong side is low so idk
btw, I dont believe the bs that the gas tank causes the lean. I installed leafs with additional preload and I still lean on the drivers side.
K tanks will keep nosing around for other problems. My first toyota so lots of things to figure out.
