1 - 2 of 2 Posts
2020 Tundra TRD PRO
After 2 days being at the shop....sound system finally installed...there was a mix up with the wrong box being ordered and the shallow mount speaker not fitting :cautious:, the shop was kind enough to loan me a pair of 2 12's Memphis shallow mount subs for the meantime until the the right box shows up for my 2 10s...initial impression of the temporary sub set-up wasnt bad, I can immediately tell they are average subs but bass and clarity of the subs are sufficient. A similar install with the same subs I originally ordered were done a week or so ago on a Tundra as well and the sound quality was excellent compared to the Memphis subs that are in there now...new mid-range and highs sound incredible compared to what it did before...
OEM JBL premium system was absolute trash, glad I made the upgrade to this....
Heres a short rundown on the parts and specs...pics at the end, not too much can be seen since they are POST-INSTALL pics...
AMP 1: HELIX M ONE CLASS D
@ 4 OHMS 1 X 240 / 480W
@ 2 OHMS 1 X 410 / 820W
@ 1 OHM 1 X 600 / 1200W
MAX POWER PER CHANNEL UP TO 720W RMS @ 1 OHM
BASS CONTROL FOR VOLUME ADJUSTMENT
AMP 2: HELIX M FOUR CLASS D
@ 4 OHMS 4 X 100 / 200W
@ 2 OHMS 4 X 100 / 200W
MAX POWER PER CHANNEL UP TO 135W RMS @ 2 OHMS
ACTIVE LINE OUT CONVERTER: WAVTECH LINK 6
6-CHANNEL LINE OUT CONVERTER
SUMMING
VARIABLE GAIN ADJUSTMENTS W/CLIP LEDS
2/4/6-CHANNEL INPUT SELECT
2/3 WAY SUMMING WITH RETAINED CHANEL 5/6 LEVEL CONTROL
FRONT SPEAKERS: BLAM 690RS RELAX
MAX POWER 150W
NOMINAL POWER 75W
IMPEDENCE 2 OHMS
MAGNET – FERRITE
FREQUENCY RESPONSE 60HZ – 20KHZ
TWEETERS: RT20 RELAX
MAX POWER 100W
NOMINAL POWER 10W
IMPEDANCE 3 OHMS
SENSITIVITY 90DB
MAGNET – NEODYMIUM
FREQUENCY RESPONSE 2.5KHZ – 25KHZ
REAR SPEAKERS: BLAM 165RC
MAX POWER 150w
NOMINAL POWER 75W
IMPEDANCE 2 OHMS
FREQUENCY RESPONSE 60HZ – 8KHZ
MAGNET – FERRITE
SUBWOOFERS: (2) 10 AUDIOMOBILE GTS2010
400W RMS
FREQUENCY RANGE 20HZ – 300 HZ
SENSITIVITY 79.8DB/SPL @ 1.0W
CONE: CLS MATERIAL
150MM 5.9 INCH MAGNET
Nice write up, Great looking install. Post pics of your RTA curve when you get a chance. I would love to see how the system performs.
1 - 2 of 2 Posts
