1 - 4 of 4 Posts
Has anyone here had any issues with the chain banging against the spare wheel maybe while off-road or over speed bumps?
Wire tie?
Have you removed the spare before? I think I remember reading that from the factory the chain is tack welded to keep it from moving around but lowering it the first time broke the weld. And yep, a zip tie is probably a good solution.
Wire tie?
this is what i did. simple fix. could not stand hearing that chain band around. tire has been down, but chain made noise even before it had ever been lowered.
1 - 4 of 4 Posts
