I've been digging around most of the afternoon trying to find an answer to this but keep coming up empty handed. Hopefully, one of you here is smarter than I am.
I installed a set of Recon projectors in my 2016. Factory harness has 4 connectors while the Recons have 3. I'm assuming the extra one is for the leveling motor in the factory headlights. From the Recons, I spliced the red wire to the purple wire going into the amber bulb connector on the factory harness. The black I grounded onto the factory ground on the fender.
When I turned everything back on, the DRL 'eyebrow' on the Recons did not illuminate although the amber did. Exactly like the factory units do. I assume that if I splice the factory pink wire, instead of the purple, the eyebrows should come on with the amber DRLs. Is that a correct assumption?
When I turn on the parking lights, only the passenger side eyebrow illuminates.
When I turn on the headlights, the projectors come on but still only one eyebrow.
Any ideas? Faulty unit? I have left a message for customer service over at Recon.
Appreciate any pointers. Thanks in advance.
