1 - 10 of 10 Posts
Not a newb, but I did a serach and couldn't exactly find pics...
My 22in Monsters on 285/50-22 Terra Grapps rub the driver side inner fender on hard right reverse. Many of you are familiar, I'm sure. The tiny mud flap has been removed long ago...when I first got my 20in Rockstars on 305/55-20 last year.
How exactly do I do the fender mod and how is it supposed to look after? Pics and a brief explanation are greatly appreciated.
Thanks
Subscribed
Did it this weekend. Worked great!!
However, plastic liner did not attach to the bumper in the same way as in the HOW TO. I basically just did the same thing though. Remove bolts, trim plastic with utility knife, drill new holes, re-insert bolts.
OK, so that's my problem. What am I looking at here? I can't find anything in the front of my truck that exactly resembles that. Am I underneath looking straight up? Or am I looking at it from the side?
If you have a 2011 it looks nothing like these pictures. Crawl under the truck and look at the front fender liner where it attaches to the bottom of the front bumper. There are 2 small screws that hold the liner in place to the bottom of the bumper. Remove the inside screw, push the liner away from the tire, mark and drill a new hole, trim the liner and put screw back in.
2011-2013 Front Fender MOD
I have seen a lot of confusion based on 350Z's excellent 2010-2007 Tundra fender mod. thread.
The problem and confusion lies because the front bumper was changed for 2011-2013 Toyota Tundra's. I'd like to start a separate thread on a 2011-2013 front fender mod. I have been working with numerous suspension companies, local 4 wheel shops, and tire shops to address the issues running larger tires on these model years.
I have a 2012 Crewmax 4x4 Base model with 2.5" front lift and 1" rear lift. I absolutely hate any kind of tire rub what so ever. I'm a self proclaimed protectionist and I see a lot of guys and gals chopping and cutting fenders, bumpers, skid plates and whatever else trying to fit their very expensive tires into 2011-2013 model years.
Toyota Tundra's unfortunately where never engineered to be lifted no matter what we all think. With that being said modifying these trucks can be a little tricky if you want to maintain a factory look and ride.
I'm actually trying to fit probably the largest possible tire size I can with my current setup. Toyo AT2's 285/75R18. FN wheels 9x18 12mm offset. These are 34.8 tires.
I have been having issues with rubbing on the front bumper and I mean the actual chrome bumper not the plastic mud guard. So I need your help to figure out what the best solution is to my dilemma. I will provide pictures of the process and feedback to any of you that are looking for a real solution that maintains a clean factory look.
Let's get something going here!
1 - 10 of 10 Posts
