1 - 4 of 4 Posts
Run down I have 2010 Crew Max 4x4 installed 4.5 bds lift w/35x12.5r20 nitto trail grapplers & regeared to 4.88 front and rear diffs. Installed a hypertech speedo cal thought I had my numbers correct but No.
Here is what I have for numbers:
First number is what I am seeing on the speedo second number is the gps reading.
35=38.4 mph
40=45.1 mph
50=55.6 mph
55=60.6 mph
60=66.6 mph
65=72.7 mph
70=78.7mph
How the heck do I correct this.Hypertech states only put the tire in inches in there software not the tire sizes and don't put the new gear ratios in Please assit Thank you
I'm pretty sure u have to put in the gear ratios. Did u call hypertech and ask a tech?
Doesn't the combination of 4.88 gears and 35" tires get the final ratio back to almost stock? I would say you need to do some math and figure out exactly how a 31" tire with 4.30 ratio compares to a 35" tire with a 4.88 ratio
Edit: looks like that combo of gear ratios and tires will only result in your speedo being off by 0.5% percent. long story short you don't need a calibrator at all
I wouldn't mess with the tire size and gearing changes in the software. The calibrator just uses a % difference conversion. Reset the unit back to factory and drive a few days to find out what % you are off from stock. (The best speed to check is with speedo reading 50 mph and multiply GPS reading by 2. that will be your % you are off. The numbers you have listed are after some kind of adjustments have already been made. They show a positive difference and it should be negative with 4.88's and 35's.
The numbers you listed You're showing roughly + 11%. If this was stock + 11% you would just need to open the software, choose changed gear ratio. Old gear ratio = 1:1. New gear ratio = 1.11:1. It would show a conversion factor of .9009 then you would just have to program and be finished.
The problem is you're + 11% over what you currently have it set for not + 11% over stock gearing. If you know what you had already put in the math could be done to figure it out but that's a little more difficult.
I'm going to bet it you put in old gear = 1 and new gear = .9577 it will give conversion factor will be 1.044 and speedo should be fairly close.
1 - 4 of 4 Posts
