1 - 2 of 2 Posts
When I go to turn on my high beams the one to keep it on it does not turn on, but when i do the intermittent one it turns on. Any help would be greatly appreciated.
Welp, is the light switch in the on position? Sounds silly, but what you are describing is exactly how the lights work when the switch is set to "off".
After that, it sounds like the stalk switch might be bad. What truck do you have? Your avatar makes it seem like a newer one that might still be under warranty?
1 - 2 of 2 Posts
