I tackled putting on 2.25" Top Gun Custom spacers this morning. Four hours into it, I got one on. Difficulty was getting everything spread apart enough to put the front strut back in with the 2.25" spacer in place. I almost gave up, then remembered I had a strut compression tool, it helped.
Problem is when I finally got the strut in place and the bottom bolt back in, I can't get the wheel hub to go back up, I have a jack under the a-arm with lift on it. But I think the axle isn't going back into the front diff. I must have pulled it applying so much down to get the strut back in place. How hard is that to get back into place??? I have turned the hub and lifted a hundred times, no luck.
Man the instructions said two hour simple install. No strut compression tool needed.
Any advice? I don't think any of our local mechanics make house calls.:eek:
Oh suck man. I was gonna do the same to mine next weekend. I look forward to hearing what it takes to figure this out. Where you at in WY?
Thermop! I got it!:D Just had to push on the knuckle-hub, and rotate the hub, until the axle lined up and went together. Whew! Then I had to use a 6' frost bar to pry the upper a-arm down to get it all back together. On to the passenger side, should go a lot quicker.
I called my son in Atlanta, he worked for a Toyota off road shop for quite a while and he said I was on the right track, just stay with it. :mad:
The bolt/nut at the bottom of the strut was so tight I couldn't break it loose with a 450# electric impact, so I put a closed end on it and put my 6 ton jack under the wrench and jacked the wrench up until it broke loose.
Just make sure you take "all" of the break line brackets loose.
Good luck with yours! :)
Passenger side took less than an hour. Key was a long pry bar. The 6' frost bar was invaluable. When I was finished, my 2.25" gave me over 3". More than I wanted but what do you do?:rolleyes:
Glad to hear you got it figured. That's crazy you had to use a frost bar! Let's see some pics when you get around to it. Did you do a diff drop as well? I've got to do mine cuz I'm going to a 3" level.
Everything on mine came apart fine when I did my front swap. \
Electric impacts normally don't really do what they say they do, or at least not in my experience.
Glad you got it figured out, now wheres the pics?
As soon as I find my camera I will do a couple of pictures. I didn't use a diff. drop. Most of the posts I read here and info from the manufacturer, were no drops for less than 3". So I didn't. I took it for a drive and tried 4x4, everything seemed fine. I will keep an eye on it. Just need to get it aligned this week.
The frost bar made it easier, more gentle leverage. A 24" pry bar just wasn't enough.
