1 - 20 of 22 Posts
So I bought a 2011 Rock Warrior Crewmax about 3 weeks ago. When I bought it, I noticed this and brought it up to the dealer, and he said it was common and easy to replace.
It is a small "rash" looking thing on the plastic molding between the front and rear doors/windows.
SO........
A. Does anybody else have this issue?
B. What causes this?
C. How can this be fixed? (cleaning solution, replace piece)
I have done some research but can't really find any info. Not exactly sure what that piece is called.
Thanks guys.
I Kick Hippies
wouldn't say it's common but is easy to replace. it's just a black sticker. the dealer will heat it up, peel off and install a new one.
Reactions: danoh
SO........
Thanks guys.
A. Not that I've ever heard of or seen - definately not "common"
B. Unknown
C. Peel it off and replace, or peel it off and leave it off. There's paint under it. It's like a sticker.
Any Idea where I can order the "sticker" and how much it costs. If it really is just a heat/peel/replace project, might be easier to do myself than deal with driving to dealer, bitching and waiting.
I sell pre-cut strips of it in gloss black or matte black for $10 per strip and you need 4 strips to do a Tundra. It's "apply and trim". VERY easy.
If you're looking for the factory replacement, they're called Blackout Tape. Toyota sells it as a left and right set.
Part number 759220C020 is for the left side, 759210C020 for the right side, $25 per side.
You could just peel it off and see if you like it. Some guys take it off but usually on black and red I believe.
If the damage is only on the tape, the fix is simple. Looking at your pictures, it seems to me that the damage goes deeper than the tape. I would definitely have the dealer take care of the problem.
If you have a car wrap place nearby, they'll have different colors/options for you to choose probably for cheaper. I just replaced the stock satin black myself a couple days ago with gloss black. Very easy to do.
May take you up on that? If I just get the one strip, will it match the others?
Just peel it off and original paint is under...
An older pic of my truck but I peeled mine off sometime last year
Reactions: MaylonTRD
Peeled mine off and ain't goin' back.
It's a one banana job really. I just left in sun for about an hour and peeled it right off. No residue, nothing.
Both of these trucks look good with it taken off.
Discussion Starter · #18 ·
Thanks for all the help guys. If I ever have a question these forums always guide me in the right direction.
I went home and peeled off the tape and after some goo gone there is just a little spot now. I actually like it with the tape better so I am going to order some and re-apply. I think the new tape will cover up the blemish. Thanks again.
put some touch up paint on it then recover it, its called black out tape. my dealership charged me $115 to install one panel on the passenger front door due to damage from a garage when i got my windows tinted
Discussion Starter · #20 ·
I ordered the replacement tape online. Was $30 for the two strips on drivers side. Don't get me started on dealership. I had a pretty amusing story with them last week when I asked to "activate" my alarm. And my wife got robbed at the honda dealership just yesterday. Paid $120 to install cabin and air filter. Needless to say she got a talking too. I showed her how easy it was to do (and wanted to check if they actually got replaced) and she was amazed that she basically paid $75 in labor for 2 minutes of work.
1 - 20 of 22 Posts
