1 - 4 of 4 Posts
Ok so I bought some 20x10 -25 wheels with 295/60R20 mud tires and was pretty excited about it. Needless to say, for those with the knowledge, that these will not fit my stock 2014 tundra. I know some trimming will have to be done regardless. My question is can I make these wheels and tires work with a 6” lift or will I need more?
Not all 6" lifts are created equal, but most 6" kits will be fine. I had a 2wd 2011 and a 4wd 2014. Both had 6" lifts with 35s. The 2014 had 22x12s with -44 offset. It will fit. Your setup is less than 35" and outside the wheel well less.
You don't need a 6" lift for 295/60's. a 3/1 will be more than enough.
1 - 4 of 4 Posts
