Need*some advice on what parts I need next to complete my led turn signal project on the front and rear of*my 2011 Tundra. I installed some 3157 led bulbs in the front turn signal locations and turned the parking lights on and they looked great. Then I hit the blinker and popped the 15a fuse under the hood. I've done a ton of searching online and from what I've gathered I need some 3157 CK bulbs in the front. So after reading all the post I put my old bulbs in and moved the 3157 led lights to the rear turn signals. The info stated that the regular 3157 leds will work in the rear.Well I made the swap and they blinked one time and never came back on. This time I got the hyper flash when the blinkers were tried. Question is do I need resistors at all fourcorners or something else? My truck has the 02c02 flasher relay already to delete theDRL's. I'm at a loss here. Thanks
