Today i was gonna install my AMP steps, so the 1st thing you're suppose to do is remove the emergency brake bracket bolt, turn the bracket 180 degrees and then install the bolt back. Well as i was doing that the bolt snapped. I wasnt using an impact tool, i was just hand tightening with a ratchet and not even that hard. Anyways half of the bolt is now stuck in the frame. Do any of you guys with any experience with this, recommend anything?
