1 - 4 of 4 Posts
Gents,
I've been installing a 3/1. I had problems with the passenger side sway bar. So I went ahead and finished the lift, put on the tires, and put her on the ground. Then I took out the mounts and hardware for the sway bar to get the passenger side it. Went in no problem. BUT when I put the bolt in, the nut came out. How Can I tighten this down? Only solution that I see is taking the lower strut bolt out, to have more room behind there. I really don't want to do that.
I am open to suggestions!
Discussion Starter · #2 ·
nevermind.... I got it! I had to lift the middle to change the angel of the lower control arm. Got a wrench in there and get her tightened down.....I was worried there for a few!
"Resident Liberal"
Did you do a Diff drop?
Tac weld the nut to the arm so it doesn't cause trouble later, it may loosen itself up, mine did in the same situation.
1 - 4 of 4 Posts
