1 - 20 of 39 Posts
I just did! I am embarrassed to post the pic but hopefully someone else will check it before it gets this bad.
I changed mine for the first time at 80k. It was dirty, but didn't have all the leaves you got. I drive 40k a year, check mine about every 3 months.
Mine looked much worse when I changed it last month...Threw it away before I could pic & post. Truck is at 107,000 miles and the ac works just like the day I bought it. These trucks are a work of art:)
Discussion Starter · #11 ·
Reactions: NIE_Cal
47k miles on my truck. Have had my homemade washable filter since about 30k miles I guess. Wash it out and lysol it 1-2x per year, or every oil change...works perfect.
what type of filter are you using, this could be a useful how-to / mod. how about a link?
Cheap, you can get them @ Napa for $12-$15 or get them online for cheaper (rockauto has them from $5-$25), but you'll have to pay shipping, so buy them in quantity to make it worth the buy.
Change them out once a year - its not like they break the bank:)
Spooge Guzzler
I just pull mine out at random and check it. If it looks good, I tap it on the fence to knock some dust out and put it back in. If it has some crap in it, I run the shop vac over it, knock the dust out on the fence and put it back.
I also run everything on recirc. That probably helps cut down on outside debri.
The $12 filter I put in there almost 2 years ago, still looks like it's a week old.
And I've probably spent a whole 4 min of my life, maintaining it.
You can get the OEM for around $15, or an aftermarket for less than $5 shipped.
I use the aftermarket, and blow it out with an air compressor between changes.
I usually blow it out and reset the service light while waiting for the oil to drain.
Spooge Guzzler
I Would pull it out and look at it at least every few 1000 miles. But, you can't go by a timeline or mileage. How often to check it all depends on how often the system is running, how dusty your area is, if there's a ton of bugs, trees, pollen, etc. in your area.
And then it's discretion. Does it just have light dust and can be blown or vac'd out and reused? Is it packed solid and needs to be replaced?
:dunno:
1 - 20 of 39 Posts
