Took me longer than I wanted, but the winch is in and running, just haven't rewound the cable on it yet. I am using a Rock Slide Engineering bumper, and it was designed for a Warn Zeon, so I had to tweak things just a tiny bit. The roller on this winch is pretty low in the winch mount so if I left the fairlead where it was designed to be, it would have a pretty steep angle up to the bottom roller which I didn't want. I haven't reinstalled the fairlead, but I opened up the hole a bit, and will remount it an inch or so lower when I get time tomorrow.
First impressions, the winch is extremely compact, and it is pretty handy that you can rotate the winch motor in 90 degree increments if needed (I needed).
It mounted up just fine to the baseplate designed for the Zeon.
The hardest part was routing the hoses, I will take some pictures tomorrow of how exactly I did it. The adapter kit they sell for 80 bucks is complete junk. The banjo nut is too thin to work with the bolt on the pump, and of course they don't send you another bolt. Also, it has a straight shaft welded on, totally unlike the existing line routing. Finally, it forces you to eliminate the sensor that picks up the idle under a heavy load, something I thought should be eliminated. Instead of fighting with their kit, I decided to send it back and have adapters made using the existing lines. I had a local shop cut the power steering line on each end where it went from rigid to flex, and braze on a AN style nut to match the included lines. For 80 bucks I got two perfect adapters, abrasion wrap, fittings, and some clamps. Way better than the little kit Mile Marker sells. I'll post some more pictures of the hose routing and such tomorrow when its daylight.
