1 - 6 of 6 Posts
Go here: ORACLE Door LED Projectors
Select your image and add the item to your cart.
Use super-savings coupon code "DOOR_LITE" to get 25% off this item!
ENJOY :D
For those of you have not seen these the projectors put the logo on the ground when you open your doors. Like this:
Discussion Starter #4
I know this is an old thread, but can you provide a wiring diagram to install this set-up in a 2011 Tundra?
Thank you
Check the back of the box for instructions you want to get constant power from the wire inside the door then ground to the door trigger so that the ground is activated and turns on whenever the door is opened.
1 - 6 of 6 Posts
