Just one more reason NOT to buy one.
ReadPermalinkEmail thisLinking BlogsComments [64]
Ford responds to flaming Super Duty video
Posted Mar 28th 2007 10:10AM by John Neff
Filed under: Trucks/Pickups, Recalls/TSBs, Ford
Our good buddy Mike Levine at Pickuptruck.com did the legwork and got in touch with Ford safety spokesperson Dan Jarvis to talk about the video we showed you yesterday that features a 2008 Ford Super Duty pickup spewing flames from its tailpipes. Jarvis confirmed that the truck in the video is one of the three pickups Ford described last week when it issued a recall to address the problem. While not entirely certain which of the trucks it is, Jarvis said it's one of the two trucks that was purchased in Canada, probably the one that was started in extremely cold temperatures (appx. minus 20 to 30 degrees Fahrenheit) and not given sufficient time to warm up before being driven. That situation could make short work of any engine, and the resultant blown bearing seal in the turbo that leaked combustible fluid into the exhaust system should not necessarily be considered a defective part.
Clearly, Ford is very concerned about the reputation of its new 6.4L Power Stroke, which is evident by how quickly it took action with a recall to address three isolated incidents that resulted in the same outcome, i.e. flaming tailpipes. The real issue in each case appears to be this newfangled Diesel Particulate Filter, versions of which are used not only by the Ford Super Duty, but also the Heavy Duty GMT900 and Dodge Ram pickups. Considering that all three heavy duty pickups use a process of regeneration to burn away accumulated particulates in their respective DPFs, the potential for flaming tailpipes exists in all three trucks if an unmetered amount of flammable liquid gets in there somehow. We're certainly not cutting Ford any slack here, but considering it likely sells more heavy duty trucks equipped with diesels than the other two automakers, statistically speaking this was bound to happen to a Ford first. Only time will tell if we're right and other diesel-equipped late-model pickups start getting hot under the collar.
