Ok,
I decided to go with a LRO 3/1 Leveling Kit with Nitto Grappler 305/55/20 tires but before I start buying everything, I have a question about my Factory Texas Edition 20" Chrome wheels w/Black Accent. (see signature picture of wheel).
I'm pretty sure the specs on my wheels are:
20x9
30mm offset
I looked on the inside of the wheel and it's stamped with [Maximum Tire 33"] but doesn't indicate the width or offset but searching the wheels online (Ultra Grinders is the brand and model and the 5x150 bolt pattern shows 30mm offset.
So My Questions are:
Will 305/55/20 look good with a 30mm offset wheel? (currently I'm running 275/55/20 on these wheels and the tire is pretty much flush with the fender).
Will it rub?
I prefer a 18mm offset wheel (like the tire to stick pass the fender a just little bit) but the only difference between a 30mm vs 18mm offset is 12mm which is only half an inch (.47 inch). How much difference can one see with a half inch difference (sticking out) wheel?
I'm not familiar with backspace as it relates to offset but if it's only .47" difference, I rather keep my stock Texas Edition wheels.
Can anyone help and/or give me some advice?
20x9
30mm offset
Will it rub?
