1 - 4 of 4 Posts
Not sure if this has been posted before or not but I was out a few weeks ago and got a wild hair up my a$$ to buy a tonneau cover for my 2017 Crewcab, I saw an Extang Encore and liked it so I bought one. The sales rep said that Extang makes a kit that lowers the deck rails so they can be reinstalled. When they installed the cover the deck rails were sitting in the bed of the truck, I asked then about it and they said they had to call Extang because the kit didn't have anything to address the rails. I ended calling Extang myself and they said they have a solution for the Tacoma but not the Tundra. I started looking for a solution on my own but couldn't come up with anything I could order, I was getting ready to fabricate my own bracket when I noticed the Toyota OEM cover looks exactly the same. I searched this site and found several threads saying the same. The OEM cover will accommodate the deck rails so, I went down the the dealer and the parts guy brought up the install guide for the OEM cover, it had part numbers for the clamp brackets so I took a chance and ordered them. Not cheap, 69.50 but I wanted the deck rails back on the truck. Two days later he called and said they were in, ran down and picked them up at lunch and installed them when I got home. Now each side is clamped on in five spots instead of the three with the Extang clamps. I was able to install the new brackets before I removed the existing clamp brackets so no issues with alignment or refitting.
Hello.
I just got the Extang Encore for my '16 SR with 8' bed.
Does anyone know the part numbers for the hardware bags, as mentioned above? I need the clamps and bolts to retain my deck rail system.
I've attached the OEM installation instructions for reference.
Thank you for your time!!
Bump has anyone tried this recently?
Any updates? Success, failure?
As I understand the T-AI-1050-D Toyota instructions, the Extang Encore has its own rails which take the place of the factory rails.
This factory kit provides 5 brackets which bolt behind the Extang rails, providing new (lower) attachment points for the factory rails.
Are there issues with the factory bedliner?
1 - 4 of 4 Posts
