I had a exhaust leak at the air induction tube where it meets the exhaust manifold. I have read that I was not the only one with this problem. So I took it to Toyota to see if I could get it covered under emission warranty as my truck had 70k on it. They said they would not cover it and was going to cost 400 bucks to pull off and put a new gasket on it. Well I'm a master ase mechanic and could tell the thing was cracked and didn't need a gasket but they argued with me anyway. So I took it home let it cool down and in 1 hour had the manifold off completely and sure enough the flange was seperated from the pipe on the manifold. I took my welder out and ran a bead all the way around the outside of the pipe and flange and had it back in. Total job took 2 1/2 hours and will never break again. So if anyone has this issue don't buy a new manifold find a buddy that can weld and have him weld it up for u. It's a way better fix than a factory replacement.
My truck is a 08 dc with the 5.7
