1 - 20 of 38 Posts
When driving on the highway 60/70mph temp gauge goes up to 3/4 mark also on hills. When driving around town small roads stays in the center mark. If I let of gas on highway it comes back to center not sure what’s causing this any ideas?
When was the last time you checked your coolant level or had your cooling system flushed and new fluid put in? I tow a 9400 lb trailer and my gauge never moves past 1/2 way.
Since we know nothing about your truck or coolant or radiator I vote for:
- change coolant
- replace thermostat. I recommend a Mama Toyota OEM cap
Chief of Grammar Police
When was the last time you had the air in the tires exchanged?
Something else to check is the exterior of the radiator. Make sure it is clean and not clogged with debris.
Discussion Starter #9
Coolant flushed and new fluid in last October level is good as of this week. Work completed by the dealership. then in January the problem started
All kidding aside, I’m willing to bet you have an air pocket that won’t make its way out, or your thermostat is wonky
Drive belt tensioner working properly and belt in good condition?
Fan fluid coupling operating properly?
@70mph, the fan is not making a difference with cooling. You could have no fan at all and would be fine as long as you never stopped. Like McGov stated, tstat.
1 - 20 of 38 Posts
