That's good to know. You're a lot braver than I am. There was a pretty stern warning that if you don't use the module the lifespan decreases significantly or will immediately burn out the LEDs. I guess the thing to do would be plug in the module and measure the output voltage. If it's around 12v you shouldn't have any issues plugging the LEDs in dorectly
I didn't lol I tied mine into the running lights. Was easier that way since I already had a wire to splice Into from having spyder halos. But you can do it that way for sure if you want.
Fit and finish is oem on these. I tied into the purple drl wire, but I'm going to switch it to a piggyback fuse to clean up the install. Heres a pic (in the back ground) I actually used white plasti dip. It matches surprisingly well. In fact, if I wouldn't have mentioned I used plasti dip no one would have probably noticed.
Finally got my DRL's installed, I ended up wiring them like mblair's d.i.y. and didn't use the white wire, figured I'd leave them bright while the bright's were on. I like the way they turned out!
21 - 26 of 26 Posts
TundraTalk.net forum offers the most comprehensive collection of Toyota Tundra information. Find discussions on the Toyota Tundra Diesel, TRD Pro, SR5, lift kits, towing capacity, classifieds, and more!
