1 - 2 of 2 Posts
This is the one that I installed in my truck from them:
REARSIGHT Camera Rear View Mirror Monitor Prewired Kit at Sparks Toyota-Scion, Myrtle Beach, SC
If you want the overhead monitor version, they have a few options. I like the rear view mirror style because its more subtle. The install was a no brainer, 90% plug and play. I thought the hardest part of it was cutting the hole into the tailgate handle and getting it perfect....a lot of filing took place after I cut the hole to get it to where I wanted it. I also put a small amount of blk loctite gasket maker around the edge to prevent anything from getting in. You don't have to add anything, but I only trust double sided tape to an extent. The best part is that no one can tell that the camera didn't come from the factory.
1 - 2 of 2 Posts
