I did a few searches and couldn't find what I needed. I just got the drive monitor switch for MPG, gallons left in gas tank and to be able to switch between metric and standard.
Well the darn thing doesn't work and I know there is a fix. I have eight wires but the only switch that works is converting the temperature from F to C. Can you help or point me to the DIY fix on the forum? Thanks
I found some DIY info on adding wires to the drive monitor switch. I am going to give it a go. Any tips on removing the instrument cluster? For the job as a whole? I am a little nervous removing the cluster.
