I have a lot more luck with rusty exhaust components when I use my impact gun. Seems to hammer them off better than with a breaker bar.
I will certainly try this as well, besides I can't get my breaker bar anywhere near that driver's side flange without removing lots of stuff that I hope I don't have to remove! I think I need a 10" impact extension.I have a lot more luck with rusty exhaust components when I use my impact gun. Seems to hammer them off better than with a breaker bar.
The cutting off is the hard part. The area is very tight and the studs are also likely rusted into the cast iron. How to reach them if the nuts strip or fail is really my concern. Or better yet, someone tell me secret formulas where electrolysis was used to dissolve turn the iron oxide back into steel and make the rust just disappear. Now why hasn't anyone done this on a simple machine you can buy on Amazon?:soapbox:You can always cut the nuts off, pound the bolts out, and replace with new stainless nuts and bolts.
That's what I suggest anyways. I had to do that on my FJ in 2008 when I was installing a cat-back.
Well, I have a lot of tools.The cutting off is the hard part. The area is very tight and the studs are also likely rusted into the cast iron. How to reach them if the nuts strip or fail is really my concern. Or better yet, someone tell me secret formulas where electrolysis was used to dissolve turn the iron oxide back into steel and make the rust just disappear. Now why hasn't anyone done this on a simple machine you can buy on Amazon?:soapbox:
I will be replacing the bolts with 304 stainless and bronze nuts with nickel anti-seize. So have you had any trouble with the stainless bolts? The argument is (I suspect from persons who don't know the stainless types) is that it stretches (expands at temperature) and hardens and gets internal granulation, etc. and fails. Any failure on yours? The only bolt I was able to remove was a stainless one with two stainless nuts. They were not galled, and had no appearance of any anti-seize. But this is very off topic.
Thanks for you reply and the vote of confidence for the stainless.
To post a pic you can just save it to your computer, and drag it to the box below the quick response area.I have all those tools, and yes, I could get my die grinder in there (I hate burr slivers). I think the set-up is a bit different here. The cat flange is bolted at the manifold end which has three star-end studs in a cast part that the cat flange goes on to and is then secured with 3 nuts. The only issue with your suggestion given this scenario, is that if I have to cut the nut off, I have to be careful not to mess up the stud, or I have to have a way to get the studs out. There is no pounding out the screwed in studs of course. Or I could try to drill and tap in a small space. I should figure out how to post some pictures, but don't have time until the weekend.
