1 - 20 of 38 Posts
Automotive Lighting Experts
2014-2017 Toyota Tundra Switchback C-Light LED Halo / Board /
DRL Strip
Made in St. Louis, Missouri by Diode Dynamics Engineering!
These products were designed specifically for each Toyota Tundra headlight style for the 2014-2017 Toyota Tundra model years. The Switchback DRL LED board replacements fit Premium-headlight equipped Tundra models only. We have designed a custom-fit C-Light which fits both the standard and premium model headlights. The Switchback DRL strip fits the standard housing only.
From the factory, the Toyota Tundra has LED accents in the premium headlights that illuminate in a white color, for the parking light and DRL. With Diode Dynamics replacement LED boards, you can upgrade your headlights by making those accents also light up as brilliant amber turn signal, with a "switchback" dual-color effect. This is a great way to stand out on the road, while maintaining a clean OEM-style appearance.
These LED boards are a direct replacement for the factory ones, but have double the number of LEDs, in both white and amber. The white LEDs turn on as your parking lights and DRLs, with a dimmed power level at night. Anytime you hit your turn signal, the white shuts off, and they light up in bright amber to indicate signaling.
You don't have to align and fasten LEDs by hand- this is an OEM-grade solution, with exact fitment, and perfect alignment of the new LEDs. Just remove the factory boards, and ours fit directly in place. Your order includes two sets of replacement boards, two drivers, and two wire pigtails with T-tap connectors - one for each side.
Made in USA, these boards utilize high-power SMD LED chips. The amber chips are a custom-manufactured down-converted 1800K LED for superior brightness compared to standard amber chips, ensuring extremely high brightness, even during the day.
To drive the high-power LEDs safely, a new constant-current, waterproof, inductive driver is included for each set. This driver utilizes a PWM brightness control system, a Diode Dynamics exclusive. This allows for a low-power white at night, high-power white during the day, and then an amber turn signal that is even brighter! While the amber is extremely bright, we do not recommend disabling your factory turn signal.
The DRL Strip halo kit, designed specifically for the 2014+ Toyota Tundra with standard headlights, includes custom-sized strips that mount on top of the non functional "DRL" segment within the headlight, replicating the factory DRL LED found on Premium models. This LED has multiple functions: brilliant amber as DRL, extremely bright white when headlamps are turned on, and flash amber when the turn signal is engaged. It will add a distinct, unique look to your Tundra both day and night!
HDHalo Technology:
These halos feature all the benefits of our exclusive HDHalo technology, including:
- Proprietary phosphor coating to create uniform, solid appearance.
- Extremely bright, high-density LEDs that are visible even in direct sunlight.
- Clean appearance in headlight when off thanks to the phosphor coating.
- Multi-function PWM drivers, fully waterproof and shockproof.
Your order includes two Tundra application-specific HD DRL "bars", two Dual-Output drivers, and two wire pigtails with T-tap connectors.
To drive the high-power LEDs safely, a constant-current, waterproof, inductive driver is included for each set. This driver utilizes a PWM brightness control system, a Diode Dynamics exclusive. While the amber is extremely bright, we do not recommend disabling your factory turn signal.
Professional installation for these products is strongly recommended, as the factory headlights must be opened in order to replace the LED panels. T-tap connectors and wiring instructions are included, to connect to your factory signal wires. The halos must be custom-mounted in position using adhesive or coated-beading wire.
Here's a link to our authorized dealer locator tool:
Find a Diode Dynamics Dealer
All Diode Dynamics products are backed by a 3-year replacement warranty.
2014-2017 Toyota Tundra Switchback C-Light LED Halos
2014-2017 Toyota Tundra Standard DRL Strip
2014-2017 Toyota Tundra Switchback DRL Boards
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Discussion Starter · #17 ·
Our Memorial Day sale starts NOW! Today through Friday, 5/29/2020, save 20% on all LED upgrades, including our Multicolor and Switchback LED Boards by entering coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.
Discussion Starter · #18 ·
There's no better time to upgrade! Through Friday, 5/29/2020, get 20% off all our LED upgrades for your ride, including our Multicolor and Switchback LED Boards with coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.​
Ok, maybe I'm missing something... For my headlights, I don't see a "board", I see an LED strip... where would this "board" go?
Discussion Starter · #20 ·
Hi Mike! I've put a link to the Switchback DRL Boards below! These would go inside your headlight housing! If you check the "installations" tab on the listing, you can see exactly how!
2014-2020 Toyota Tundra Switchback DRL Boards
1 - 20 of 38 Posts
