1 - 4 of 4 Posts
Professional Mall Crawler build :rockon:
VEHICLE SPECS:
-2013 Rock Warrior Edition Tundra 4x4 W/Tow package
-5.7L V8 Flex Fuel
PERFORMANCE:
-Intake Stock (I believe that Tundra intakes are already close to CAI)
-Dirty Deeds Industries 6" system with Helmholtz Resonator (No DRONE Even When Towing!)
-Fumoto Engine Oil Drain Valve
WHEELS/TIRES:
-TRD Rock Warrior Rims
-Powder Coated Beadlocks Gloss Black
-285/70/R17 BFG KO2's
-Bora 1.50" Wheel Spacers all around
-Brakes OEM
SUSPENSION:
-Fox shocks 2.5 front DSC W/ Remote rez
-Fox Shocks 2.5 rear DSC W/ remote rez
-SVC Boxed UCA (Adjustable)
-Coachbuilder +3" Shackles
-Coachbuilder Billet Carrier Bearing Drop Kit
-DIY Rear Diff Breather relocation kit (Behind Driver Tail)
ARMOR:
-SDHQ ABS Guards
-DIY Heavy Duty Truck bed liner spray undercarriage
-DIY Bed stiffening mod
RECOVERY GEAR:
-Hi-Lift Jack
-Bubba Tow rope
-Bed Stow shovel mod
-Bed mounted Fire Extinguisher
-Interior and Bed Mounted First aid W/ Trauma kit (gunshot + Tourniquet)
COMMS:
-BaoFeng BF-F8HP (UV-5R 3rd Gen) 8-Watt Dual Band Two-Way Radio (136-174Mhz VHF & 400-520Mhz UHF) X2
-BaoFeng Power Chord Adaptor
-BaoFeng Trucker Handheld
POWER MANAGEMENT:
Quick Attach 12v inverter to DC
LIGHTING:
BHLM Mod for Headlights
LED ballast front Headlights
Baja Designs Squadron Pro X2 Spots
SDHQ A-Pillar mounts
Toyota style A-Pillar Light switch Wired to 5-pin Relay
EXTERIOR:
SnugTop Rebel camper
INTERIOR:
-Weathertech FloorLiners
-ESP Plastic Rear Seat Storage
-Mr. Tint 35% front
-Plastic dip door trim
-Rockford Fosgate 5 channel P1000X5
-Polk Audio DB651 6.5'' 2way X4
-Kenwood KFC XW1200F Excelon 12"
-Stock Touchscreen Headunit (used low bypass -> High)
-Gun Vault Biometric
2019 Mods/ Goals
Secondary Air pump breather kit
315/70R17 BFG KO2 (Go bigger)
Poly bump stops
1 - 4 of 4 Posts
