Info in this thread is my Thank you note for this community. I recently accuired '08 SCSB 5.7l truck and I am going through some updates to refresh it a bit. I was able to find bunch of helpful info here for my little projects. Thank you for the info gentlemen.
I got Denso navigation unit couple of days ago and started instalation today. Toyota face number for Denso navigation unit with "built-in type amplifier" is NSCD-W12U-B. This unit is commonly refered to on this website as "non jbl navigation" or " entune navigation".
For starters I was able to confirm that wiring diagram for this unit is aviable in Toyota Tundra 2012 EWD. I went through some related threads and believe much of the confusion related to instal of this unit could be avoided if diagram was wider known. '12 Tundra EWD related section is 14 pages long and shows connections of camera, microphone, and etc. Including connector faces and numbers.
There was also some confusion on connector avialiability. Please understand that every single connector for Toyota is cross referenced in EWD to part number and therefore available for purchase at Toyota. Connectors are supplied bare, w/o pins, I usually source individual pins from junk wire harness. Individual pins just simply click in/ lock in place at connector port.
Anyhow, beside making parts list I was function testing unit today.
Plan for tomorrow is to order connectors and microphone fro Dealer and install gps antenna. I have located factory spot for gps antenna. Unfortunately location apear to be pita. If I am able to install antenna bracket w/o removing dash I will post pic of the location.
