1 - 10 of 10 Posts
lights flashing.
ABS, 4 hi 4 lo, traction control, etc.
Anyone have any ideas?
2015 crewmax 4x4 with 75k kms
Thanks
Speedometer Tachometer Trip computer Gauge Odometer
Crawled under the truck ...right rear ABS sensor was cracked off at the connector.
I replaced it...cleared the codes...took it for a drive...and all the same codes came back.
I actually haven't figured it out yet...all the same codes came back on after I replaced the sensor. I can clear them all but they keep coming back once it drive it for a few km's.
I have the negative terminal removed from the battery right now...I'm going to leave it over night and take it for a drive in the morning.
Does it go into 4WD (hi or lo)?
What are the codes telling you?
If more than one you need to address each one individually.
1 - 10 of 10 Posts
