1 - 19 of 19 Posts
Hey guys,
I've been reading up on searching but haven't heard of any rubbing while going into on ramps.
My issue is this:
I currently have 20x9 +25 Novocaine BMF wheels running 295/65/20s and a 3-1 level kit. I don't have front mud guards and removed some of my plastics in front of the wheel well. I have no rubbing, however, when entering or exiting an on/off ramp, I get rubbing. Not serious, but enough that it affects control-ability.
Will getting 295/60 work better? Or should I even drop down to a 285? From what I've read everyone was pretty happy with 296/60s
Thanks,
Mark
Could you be rubbing on your skid plate? Or is it the body mount?
Doing some intensive searching. I came across some threads about 33s or 305/55s. I really like the look of the 35s but if its rubbing during on/off ramps, I'm getting rid of them.
Can anyone speak on behalf of the 295/60s (34s) with the 3-1 kit?
I found the following pic which has 305/55 (33s) Not bad actually.
I have 305/55/20 on a 3/1 level kit with no rub. 35s seemed like too much hassle to me. I didn't want to have to chop body mounts.
Reactions: shiggydiggy
Reactions: NJMonster
Discussion Starter · #9 ·
Are you sure its rubbing the bm? Did you remove the mud flap that goes over the bm? Did you push the fender liner in? I'm running 35x12.5x18 +12 offset with a 3/1 and no bm issues what so ever.
Positive. I'll take a photo of where it rubs. Mud flaps gone and I've pushed the fender liner in as much as I can. I used a heat gun to push the fender liner.
Wow! What rims/tires are those?!?! Those would look beeeee-yooootiful on my 13 Black CM!
Read Only
My buddy has the same setup as me with a 3/1 but with bmf 10 offset I think. His will rub a little bit going into a curve hard. He has To go 295/60s. I think with a 25 offset you might be better. Not 100% sure though. I run 305/55 with no issues on 30 offset XD Hoss
I have 295/60/20s and i had to remove the mud flap and push in the front plastic. i am running them on the 9" wide bbs wheels
i now have absolutely no rubbing anywhere.
Discussion Starter · #16 ·
So we have identical set ups... however, I'm running 295/65/20 and I only rub on the body mount. I dont have my mud flaps and I've actually removed the front plastics. I also pushed the upper plastic in toward the engine bay using a heat gun.
My wheels are 20x9 wth a 25 offset. With your current 295/60s you dont rub on a curve when taking it on an on-ramp?
Below is where I rub, back of the wheel well.
not at all.
maybe its the 65 portion of the tire
i also have the 1.5" wheel spacers but it should nt make a difference
hmmmm
Discussion Starter · #18 ·
not at all.
hmmmm
Oh cool... That's comforting to hear. I'd really like to go with the 295/60 (34s) option rather than going all the way down to 33s.
I was thinking about the spacers but I dont think it'll help or make a difference.
Thanks!!
1 - 19 of 19 Posts
