1 - 9 of 9 Posts
08 76K miles. 4x4.
4LO and VSC blinking, TRAC and CEL constant. I could still engage 4HI and 4LO, The vehicle drove normally.
I have OBX LT and DT y pipe.
Lights started going when I went to some mud.
Any thoughts? I did some research and it could be, bad TPMS wire, ZPT needs to be done, Something with air?
More like a wheel speed sensor or wheel speed sensor wire was cut. Been there, done that, got the t-shirt.
Get under there and look at all 4 wheels. Let us know.
KO
I get the same thing every so often.. do you know the CEL code yet? mine comes on with a code for the secondary 02 sensors. I believe its P1001 and P1002. I could be wrong though. If you clear the code and then restart the truck all the lights will go off.
I have headers and y-pipes too and I'm certain mine is due to a 02 sensor problem.
First happened to me when a heatshield contacted an 02 sensor and rubbed the insulation off a wire and was grounding out. Its possible something similar is happening to you too with mud/water.
That might be something right there. One of my O2 is close to the insulation, going to check it out.
It still happens to me under heavy load especially at higher altitudes (7-8,000 ft). But even when they light up the truck runs fine.
I think I was getting P0137 with my problem which was low voltage on the secondary 02... that P0607 is kinda scary. Maybe the PCM got wet or jarred loose while offroading.
1 - 9 of 9 Posts
