1 - 10 of 10 Posts
All my vehicles are coated with Opt-Coat Pro Plus.
I like the coating and will have any future vehicles coated. I'm sure if you know how to polish a vehicle you could do it yourself with one of the do it yourself kits available. The Opti-Coat pro Plus that we have on our vehicles has to be installed by a certified installer. It cost me $900 each parts and labor.
Is that something you can do yourself or do you have to have a professional do it? I'm guessing you like it?
I got it, not really impressed with it. I still see scratches here and there and they claim no scratches at all. I do get compliments about how clean it always looks.
I'm also looking for better technology on paint protection beyond sealants, and found the video below.
Ceramic coating can be done yourself, but correct preparation is complicated, extensive, and labor intensive. A comment on the video asked if this was a full day job...at my age, it would take me all week, if I finished it at all. I can understand why someone would pay to have this done for them.
One other comment...If you have pre-existing defects like swirl marks or scratches from washing, they have to be polished out using a DA polisher and compound (moderate or worse) or polish (light) before applying the ceramic. Ceramic is simply protection; it won't remove or hide pre-existing defects.
https://www.youtube.com/watch?v=byKcYsEyWGk
Yes the color correction is what takes up the most time. My truck went straight from the dealer to the shop. They do good work and they have a facility to do it. I just get bummed when I see scratchers around the door handles. Plus too keep the warranty you have to take it yearly for inspection.
I have detailed part time for over 10 years and dabbled with quite a few different coatings. I actually have the ceramic pro UK version in the garage and was debating putting in on my new 18' Crewmax but won't be able to until summer because water cannot touch the paint for 24 hours and I don't have a garage to park in overnight (every night we get a good mist/dew)
The paint does need to leveled and prepped correctly. In addition it is somewhat tricky to apply depending on the paint type, weather temp and lighting. I recommend only installing in a garage with good halogen lighting. I used the old CQuartz on my superwhite 08' DB and it left a few streaks that drove me crazy. Once I finally got around to polishing, I realized the stuff is pretty legit as it was not easy to remove and took some pretty serious compound/polishing to remove.
Regardless though, it's not bulletproof and although it does add some scratch resistance (to some paints more than others, yes every paint is different) you should care for the paint as you did before. This is just meant to give you a bit more of a buffer for error down the road, for bird bombs, help repel dirt, etc...
If you aren't confident doing a 1-2 step machine polish then I recommend using a professional.
I had full paint correction done and cQuartz applied. I also use Echo2 after i wash it and its been 2 years and it still looks amazing!
I recently had full paint correction and Opti-Coat Pro applied to my 2010 Tundra, and the results were pretty amazing. I wasn’t looking for total scratch proofing. I did it primarily to protect the clear coat from breaking down. The detailer kept my truck for nearly a week, doing many steps on the paint and other surfaces to bring them back to life. I posted with pictures in the general forum.
1 - 10 of 10 Posts
