1 - 20 of 23 Posts
I had my exhaust re-done and i absolutely love it. I had Thrush glasspacks and wanted something louder. Did the whole cat delete and super 40's on both sides. But when i looked under the truck i noticed that there was still 2 more cats. So i went back the next day and they removed them. The truck sounds amazing, until i get going it sounds like a good deep muscle car rumble. Very loud and clear. Only thing i know that taking all cats off was going to set the check engine light. Does anybody know how to get rid of the light? Not really a big deal if i cant get rid of it. I swear i love just hearing my truck start up. If anybody is in the north area of jacksonville florida take your truck to S&S custom exhaust off of Beach BLVD. Went in and was out in an hour and a half. Get little shop.
· Cereal Killer
Yes it will set a CEL. The solution is simulators for the rear O2 sensors. I believe URD sells them. I have also seen some create their own simulators by making custom extra long sensor bungs which mount the sensors partially out of the exhaust stream. Somehow that gets the job done too. :dunno:
Underdog Racing Development
You WILL get a P0420 or P0430.. This was my only answer for now and it works. I heard Sparks sells them for less but I can't find a link on their site. They have a messy not user friendly website for aftermarket parts..
this may be a dumb question because im not a mechanic and just learning how to do these kinds of things. Does it go around where the cats needs to be or is hooking up to the computer?
You could try and buy some sparkplug defoulers and drill them out with a 1/2 in bit and put them where your sensors go and then put your sensors in them, you would need the short and long ones one of each on both sides. Should cost about 10 $. Have not tryed on our trucks but have seen it work on bmw's and other cars and trucks.
I tried the NonFouler extentions, drilled them out, even doubled stacked them. It didnt work, still got the P0420/430.. I gave it a good fight but that blasted ECU is too dam smart/picky..
The O2 sims are just in "inline plug" that plugs inbetween the stock O2. It still takes the readings of the O2, but sends the ECU a much much lower reading. For mine it went from around say 9.5 to a .075.... on my code reader, a super low reduction for sure..
Well I did the cat delete, and I knew my engine light would come on but today my maintenance required light came on. Does anybody know why that would come on?
Discussion Starter · #15 ·
I did just one cat on both sides and no light, but it wasn't loud enough for me. So I went back and got the other two removed then my light came on. No it's not the oil just got one done about 1k ago. That's what I thought at first but I'm clueless now.
If you delete any of the cats ur check engine light will come on. You can get a o2 sim from sparks Trd you just have to email them and ask for the price and how to order. I added mine to the header order or you can get them urd. As for the mant light could it be possible it was not reset after the oil change?
1) URD O2 Sims $180 + $? Shipping
2) Sparks O2 Sims $150 + $10 shipping
3) the O2 only monitors the FIRST Cat, not the second Cat. So if you remove the First Cat, you will get a P0420/430..
4) Your maintanence light coming on was purely coincidental. Mine just turned on today when I hit 75,000. To turn it off, push your trip button to the "A" setting, let go, turn off the engine. Then hold down the trip button, keep holding it down while you turn the key to the ACC only, you will see these 5 solid squares where the numbers were, they start to blink and then you'll see each solid square start to dissapear from left to right until you see only one then you'll hear a beep that the maintanance light has cleared. You are now good to go. Its just an idiot light to remind the driver/owner to change the oil, but it doesn't know if you already did it and goes by the miles..
any vids/sound clips?
1 - 20 of 23 Posts
